Jonathan K Posted February 3, 2010 Share Posted February 3, 2010 Greeting all! We are using VW2009 Spotlight with Renderworks. Been using VW for years to do 2d plots so I am somewhat familiar with the software. At any rate I am spending some slow shop time to learn some of the 3d render aspects of Spotlight. Started a simple file to learn the basics. 1 lighting position with 1 par can and 1 focus point. I am sure I am missing something basic here.... The lighting device does not give the check box to "Turn Light ON". All we get is the "Draw Beam" option. The light was inserted properly with the instrument insertion tool. What might I be missing? Quote Link to comment
michaelk Posted February 3, 2010 Share Posted February 3, 2010 Open the Visualization Palette. All the instruments will be listed there. The name will be Channel Purpose UID. If you don't have a channel or purpose you will only see the uid. You can turn the light on, add lit fog, etc from there. hth michaelk Quote Link to comment
Jonathan K Posted February 3, 2010 Author Share Posted February 3, 2010 Hello Michael, When I open the visualization palette there is nothing there. Just the header for the palette. I went ahead and assigned channel and purpose but still nothing shows up in the Vis palette. Thanks for the fast reply! jk Quote Link to comment
Vectorworks, Inc Employee klinzey Posted February 3, 2010 Vectorworks, Inc Employee Share Posted February 3, 2010 You should also be able to right click on the lighting device and select "Edit Light..." (Not "Edit...") You should be able to directly asscess the light from here. If you are using the Viz Pal try viewing All the lights and not just current scene. Quote Link to comment
michaelk Posted February 3, 2010 Share Posted February 3, 2010 Also make sure the viz palette is on the light tab, not the camera tab. Then below that select the "all" button (not "current scene") hth michaelk Quote Link to comment
Jonathan K Posted February 3, 2010 Author Share Posted February 3, 2010 Ok so i got the Vis Palette sorted out and can see all the fixtures and options. Yes, "Edit Light" also works. Any ideas why these options don't appear in the OIP for me? One last thing, how do you turn the fog down from 11 to a more reasonable 4? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted February 3, 2010 Vectorworks, Inc Employee Share Posted February 3, 2010 With the introduction of the Viz palette we wanted to give the physical rendered light control so that now all lights are accessible in the Viz palette. Once you start using it you will find it a lot easier. The lit fog is a Renderworks Background. You can edit it through the resource browser. Quote Link to comment
Jonathan K Posted February 3, 2010 Author Share Posted February 3, 2010 Brilliant! Thank you gentlemen. Quote Link to comment
michaelk Posted February 3, 2010 Share Posted February 3, 2010 Before you play with the fog renderworks background, you might want to look at the angle falloff and distance falloff settings. They make a huge differance. Quote Link to comment
Jonathan K Posted February 3, 2010 Author Share Posted February 3, 2010 (edited) I was playing around with that as you posted in fact. Changing the falloff's to smooth and the Lit Fog texture to Hazy really did the trick. Huge difference indeed! Too bad, it seems, that you must do 1 light at a time. Edited February 3, 2010 by Jonathan K Quote Link to comment
michaelk Posted February 4, 2010 Share Posted February 4, 2010 au contraire... You can shift click or command click (on a mac) as many as you like, choose edit and change the settings for all of the selected lights at once. hth michaelk Quote Link to comment
Jonathan K Posted February 4, 2010 Author Share Posted February 4, 2010 (edited) I am working on a Mac but have a windows style mouse. Mac mice are awful imho. Anyhow. I can select multiple lights, yes. From the Vis Palette I can shift click and select as many fixtures as I want. When right clicking them in the selected group and choosing edit I get the diet version of the "Edit Light" window. It does not have any of the beam control attributes. I should have said in my previous post that the beam options go away with multiple fixtures selected. Edited February 4, 2010 by Jonathan K Quote Link to comment
michaelk Posted February 4, 2010 Share Posted February 4, 2010 I had to go back and check... The diet edit pallet is a 2009 thing. 2010 lets you edit the angle falloff and distance falloff of multiple instruments. Tell your boss it's time to update! michaelk Quote Link to comment
michaelk Posted February 4, 2010 Share Posted February 4, 2010 2010 lets you edit the angle falloff and distance falloff of multiple instruments. ....as long as they are the same instrument type. Quote Link to comment
Jonathan K Posted February 4, 2010 Author Share Posted February 4, 2010 Trust me, he knows! At least I got him to buy me the VS-4 plugin. Thanks again for you replies! Quote Link to comment
