Markus Barrera-Kolb Posted January 29, 2010 Share Posted January 29, 2010 Can anyone enlighten me as to how I might be able to obtain the Z values of stake objects in a worksheet database row? I need to do average building elevation calculations for which the elevation at points every 10' around the building perimeter need to be averaged. Thanks! Cheers, Markus Quote Link to comment
Jonathan Pickup Posted January 30, 2010 Share Posted January 30, 2010 a worksheet will do this for you. You can create a worksheet using the Create Report... command, but that will only do half the job. the other half you have to do manually, you have to edit the header to =ZCENTER to get the elevation of each stake object. If you need a tutorial on worksheets, check out the short sharp manuals i have written Quote Link to comment
Markus Barrera-Kolb Posted February 1, 2010 Author Share Posted February 1, 2010 Jonathan, thanks for your reply. I'd tried =ZCENTER before and got no value in return -- VW doesn't seem to interpret it as a function, at least not 2008, which for better or worse is what I'm still on. Is it perhaps simply that VW can't obtain a Z value for a stake object but would be able to do so for a 3D locus? Though if I understand it correctly, the stake object is positioned using a 3D locus. Or is it functionality that was added with '09 or '10? Thanks, Markus Quote Link to comment
Jonathan Pickup Posted February 2, 2010 Share Posted February 2, 2010 Did you make the report for all the stake objects? Quote Link to comment
Markus Barrera-Kolb Posted February 2, 2010 Author Share Posted February 2, 2010 Yes, the report should be returning all of the stake objects on my site model layer, in the ABE (average building elevation) class -- see attached screen shots of the database criteria, the worksheet, and the OIP for one of the stake objects. Is ZCENTER definitely a supported function for VW 2008? Quote Link to comment
Jonathan Pickup Posted February 2, 2010 Share Posted February 2, 2010 i think it is the way you have created the report. listing objects by their layer and type rather than their record formats. Creating a report using the record attached to objects is a powerful and easy way to get the information attached to objects. I have written manuals on this. If anyone wants a simple introduction to worksheets, get the Essential Tutorial Manual from the training guides page: http://www.nemetschek.net/training/guides.php can you send me the site model part of you file, and I'll see if I can make it work. Quote Link to comment
Markus Barrera-Kolb Posted February 2, 2010 Author Share Posted February 2, 2010 Thanks Jonathan, that's very kind of you. I thought about trying to use the stake object record format, but I didn't see a record field in that format that looked like it would contain the elevation. In any event, I'll attach a file with the DTM, stake objects, and the worksheet. Quote Link to comment
Jonathan Pickup Posted February 2, 2010 Share Posted February 2, 2010 (edited) your average is 3402.075ft Edited February 2, 2010 by archoncad Quote Link to comment
Markus Barrera-Kolb Posted February 2, 2010 Author Share Posted February 2, 2010 I'm not sure how you got that result - the stake object elevations range from around 275' to 289'and the average that I calculated by hand was 298.95'. Were you able to extract Z values from the stake objects in the worksheet? Quote Link to comment
Markus Barrera-Kolb Posted February 2, 2010 Author Share Posted February 2, 2010 oops, that was supposed to be 283.95' -- either way, it's definitely not in the three thousands... And I'm still wondering whether 2008 supports =ZCENTER ??? Cheers, Markus Quote Link to comment
Jonathan Pickup Posted February 3, 2010 Share Posted February 3, 2010 I've changed the units in the file to Feet, now I have 283.506' as the average of the 20 points. I'm not sure why it doen't work with feet and inches, but it works with pure feet. Quote Link to comment
Markus Barrera-Kolb Posted February 3, 2010 Author Share Posted February 3, 2010 Are you using ZCENTER in the database row? I still don't get a valid function in my worksheet using that, regardless of whether I set the document's units to feet, inches, or feet & inches... Quote Link to comment
Markus Barrera-Kolb Posted March 11, 2010 Author Share Posted March 11, 2010 OK, I've finally upgraded to 2010 and ZCENTER does now work, although oddly I'm having to divide the elevation by 12, even though I have the field set to use the doc's default dimension unit -- feet & inches -- but that's no big deal. Now I'm trying to extract the ID Number in a database field as well, but can't seem to find a record field for it. Is this a piece of data that is embedded in the PIO that you can't access in a worksheet? The Stake record format does have "Stake #" and "polyline ID", but those are different than the "ID Number" that you can set in the Stake Object's OIP. Cheers, Markus Quote Link to comment
Pat Stanford Posted March 12, 2010 Share Posted March 12, 2010 ID Number 'Stake Object'.'ID' Also check out the script for listing the fields of PIOs located here: http://techboard.vectorworks.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=108487#Post108487 Quote Link to comment
Markus Barrera-Kolb Posted March 12, 2010 Author Share Posted March 12, 2010 Thanks Pat, that's a great script. Funny enough, Julian Carr just emailed it to me as well, after I'd asked him about WinDoor record fields. I'm sure it'll be useful on more than one occasion... Cheers, Markus Quote Link to comment
