EugP Posted November 16, 2009 Share Posted November 16, 2009 Hi, I would appreciate help doing what is probably easy but I can't figure it out. I need to insert a 6" fire sprinkler pipe 10' high that spans a 55' long space. When I try to use the 3D round tube object I can't seem to give it any length, and I can't seem to insert a 2D object and then extrude it to a length. The idea of taking a double line, rotating it and then extruding it seems ludicrous because the symbols are all there. Obviously I need some practice, but the help files are so sparse as to be useless. Thanks for any help. Quote Link to comment
CipesDesign Posted November 16, 2009 Share Posted November 16, 2009 Try simply changing to a side (profile) view and then draw a circle. Then just extrude the circle to the correct length. As always with extrudes you will need to go to top/plan view to re-position it (as all extrudes are created from o,o). Also, you can stretch (reshape) extrudes by grabbing their resize handles, so I often don't worry so much about the exact length of the extrude during creation, I just go to top/plan and pull the ends to where I need them to be. Hope that helps... Quote Link to comment
mike m oz Posted November 16, 2009 Share Posted November 16, 2009 The Tube object creates an extrusion. Switch to an elevation view and place the object on the page giving it a height parameter and then a radius value. Then move it to the required location (rotating as required). Quote Link to comment
