Jershaun
My Wish List for VW2011
Hi
1. I think any program that claims to be BIM should have window schedules linked to the model. Something like the video below.
http://www.graphisoft.com/ftp/marketing/ac13/nfc/02/02.html
2. Wall components should be shown in any view, 2D and 3D. See video below (after 3).
3. 3D Hatches. See video below.
http://www.graphisoft.com/ftp/marketing/ac13/nfc/04/04.html
4. Better engineering tools. Including 3D.
5. Multi Core support.
6. Native 64-bit support.
7. Real intelligent objects. If one object changes, then others should be intelligent enough to Adapt. See video below.
http://www.graphisoft.com/ftp/marketing/ac13/nfc/08/08.html
8. OpenGL should be default when changing from 2D Plan view to any 3D view. Also more stable OpenGL therefore one can work in an OpenGL rendered view at all times.
Thanks,
While on a sheet layer, select a viewport and choose Create Section Viewport from the View menu.
Thank you for this tip, Kevin. This seems to be new in 2010, I cant get it to work in 2009
Not new for 2010--I've been using feature since 12 (or earlier-can't remember).
Be sure to select the desired VP first.
My mistake, I tried to use a section layer viewport. Works like a charm on regular viewports, thank you. It is always a great moment for me, when I learn something new in Vectorworks. Thank you for your tips.
