Twickenhaman Posted August 4, 2009 Share Posted August 4, 2009 Hi from a novice, Is there any reasonably detailed info on modeling 3d objects such as an oval washbasin readily accessible. I have tried extrude along path with a profile and say an oval path with mixed success. I would like to be able to do this with some predictability though. Perhaps this is the wrong way to do it and thats what I need to find out. Thank you David Quote Link to comment
islandmon Posted August 4, 2009 Share Posted August 4, 2009 Try RevolveWithRail ... works great with most shapes ! Create the inner and the outer profiles separately, then after RevolveWithRail combine them into an AddSolid shape. For non-circular basins you can punch out the drain or create a separate drain profile ... Quote Link to comment
Gytis Posted August 4, 2009 Share Posted August 4, 2009 Ditto, as islandmon describes. For a little faster modeling with a little less precision, try only inner or outer profile and Shell Solid... Quote Link to comment
Twickenhaman Posted August 4, 2009 Author Share Posted August 4, 2009 Thank you both David Quote Link to comment
mike m oz Posted August 4, 2009 Share Posted August 4, 2009 Have a look at the bathtub example on the 3D Power Pack Samples page. Download it and unpick: http://www.nemetschek.net/3DPowerpack/samples.php Quote Link to comment
