Kevin McAllister Posted July 19, 2009 Share Posted July 19, 2009 Have 3D snaps been downgraded in VW 2009? I stumbled across a tech tip online where you could double click on Snap to Object to set a 3D snap preference. This preference allows you to snap to the centre of circular surfaces on cylinders among other things. It turned out the tip was for VW 2008. (I opened up my copy of 2008 and it indeed works) The option doesn't seem to have disappeared VW 2009. I though perhaps it had been integrated into some of the other options, but I have not been able to get it to snap to similar points. Has anyone else had a similar experience? Kevin Quote Link to comment
Jonathan Pickup Posted July 19, 2009 Share Posted July 19, 2009 i think 3D snaps are much better in 2009. Double click on the snap to object to open the settings. there are several to choose from, I have them all turned on. I can find the centre of the extruded circle, but not the center of the extruded rectangle. a new trick on Vectorworks 2009 is the ability to find the midpoint between smart points. move to a point you want to be a smart point, wait until you acquire the smart point. move to a new point. when you acquire the smart point you get a small grey marker between the two smart points. Quote Link to comment
Jonathan Pickup Posted July 19, 2009 Share Posted July 19, 2009 i made a youtube moview you can watch. Quote Link to comment
Kevin McAllister Posted July 20, 2009 Author Share Posted July 20, 2009 Thanks Jonathan. You are a great resource to the VW community. The "Nearest Point on Edge" checkbox under Object Snaps seems to be the key. It is turned off by default and since I wasn't trying to snap to an edge I didn't think to try turning it on. Kevin Quote Link to comment
GWS Posted July 21, 2009 Share Posted July 21, 2009 Jonathon That 'mid-point between snap points' is great, thanks for the tip. I use the snap points alot and that is a real help Guy Quote Link to comment
