MBMD Posted January 21, 2009 Share Posted January 21, 2009 Is there a way to convert walls, doors, and windows, to lines? Quote Link to comment
Pat Stanford Posted January 21, 2009 Share Posted January 21, 2009 Modify Menu:Convert to Lines or Convert Copy to Lines. Quote Link to comment
ionw Posted January 21, 2009 Share Posted January 21, 2009 While Pat's method does what you are after, I prefer to use the Ungroup command. It will ask you if you want to ungroup high level objects, say yes and continue ungrouping until you you object counts no longer increases. For example a single wall with a single door took three Ungroups to make it entirely primitives. The reason I like this is that it gives you all the component parts of the doors and windows. Door swings are arcs, wall-component fills are maintained. It really depends on what you are after. HTH, ion Quote Link to comment
MBMD Posted January 22, 2009 Author Share Posted January 22, 2009 Thats what I needed. Thanks Quote Link to comment
MBMD Posted February 9, 2009 Author Share Posted February 9, 2009 When you use the - Modify Menu:Convert to Lines or Convert Copy to Lines command, it removes the windows and doors when you do hidden line rendering. If you do the wireframe rendering it leaves the doors and windows but it also does not convert the wall to just one line. It has multipule lines on top of each other. Is there anyway to get it to leave the doors and windows and leave only one line walls? Quote Link to comment
