MBMD
Content Count
60 -
Community Reputation
0 NeutralAbout MBMD
Rank
Apprentice
Personal Information
Location
iowa
Recent Profile Visitors
Is there a way to get the slope dimension tool to show fractions instead of decimals?
Is there a way to show a 4" hollow metal masonry head on the frame of a Vectorworks 2013 door?
From what I've read on past post, there are a number of people having issues with Xerox plotters and vectorworks. We have both Mac's and PC's running VW 2010 and having issues with our new Xerox 6604. Has anyone found a driver that will work correctly with Xerox plotters and vectorworks?
I currently have Vectorworks 2010 on a Windows XP computer and I've been having more issuses crashing Vectorworks 2010 then I had with Vectorworks 2008. My question is if I update to Vectorworks 2011 is this going to be the same or get worse being it's built more for Windows 7? Also when will Windows XP not be supported by Vectorworks programs?
I just tried the file on a Mac and it shows correctly. It has to be a glitch with vectorworks showing in windows xp.
There has to be a bug. It acts like a bug because if I keep clicking on and off the viewport it will change from 1/8" to 3/16" in the object info box. I just had another guy in the office open the file and he had the same issue I did. We both have VW2010 SP4. with windows xp.
There is no confussion between the drawing scale label. When I click on the viewport the object info says the scale is 1/8" and that is not correct. When I orignally set the viewport scale I picked 1/8" from the object info - scale drop menu. What I get is a box saying 1/8" and a viewport at 3/16". This is a serious glitch in the program.
Here is one of the files doing this. When I open it and click on the viewport the object info will say 1/8" scale but it isn't. If you click off it and back on to the viewport the scale will change in the info box.
Vectorworks 2010 has a glich with the scale of Viewports. We've had several drawing files with one or multiple viewports showing the incorrect scale. The Object Info of the viewport will call out 1/8" scale but the viewport is showing a different scale. The design layer and viewport have the same scale. If I go and change the viewport layer to another scale and then back to 1/8" it may or may not scale correctly. I've got SP4 and we still have the glitch.
Is it possible to make a double door with one leave bigger then the other in VW2010?
In VW 2010 is there a way to convert a basic 5" wide wall with no fill into two lines without deleting doors and windows. When I ungroup the wall it makes a centerline and a filled polyline. I don't want either of these to appear. I just want the two basic lines. Is that possible?
Never mind. Found the problem. Corrupt file folder.
I have a number of files recently saved in VW 2010 with all the updateds to service pack 3 that can not be opened now. I get a message saying the files were saved in a newer or to old of a version. Any ideas on how to get them to work again?
Does anyone know where I can get a Ledgestone hatch?
Is there a new version of Autocad out that VW 2010 can not import?
