Final Quality Rendering Resolution
C W
I think this is what your after, in the Navigation Pallette, right click in the sheet layer that the viewport is on, then click edit, the DPI will be around 72, I have mine set to about 150-200 then for my final presentation I have been upping to 300.
1. Document Preferences: Resolution. Make sure it is set to higher than 72 DPI for printing and PDF.
2. VectorWorks Preferences: 3D 3D Conversion res. Set to High or Very High
3. Sheet Layer Page Setup. Make sure the resolution is set to higher than 72 dpi
4. Use Custom Renderworks instead of Final Quality. There are some settings there that you can turn up the resolution.
Pat
