Jim_Allen Posted October 16, 2008 Share Posted October 16, 2008 I am a bit baffled. I have created a set with the wall tool. When I go to apply a texture to the wall it only applies it to the top and sides of the wall, not the face. I know I am missing something simple, but I can't figure it out??? Quote Link to comment
Pat Stanford Posted October 16, 2008 Share Posted October 16, 2008 In the Texture Pane of the Object Info Palette (OIP), check and make sure that the Part selection is set to Left or Right, not Overall. This is necessary even if you are dragging a texture in from the Resource Browser. Pat Quote Link to comment
CS1 Posted October 16, 2008 Share Posted October 16, 2008 I find that if I have an existing wall that I didnt set up the textures before creation, then go in to the render section of the OIP and change left/right to "all", the texture applies to all sides. If I then associate a different texture to that wall it doesnt take effect to all sidesm I have to reselect the wall change the all to left then back to all again. this happens with all walls that I try and associate a tecture after creation. If I use the wall tool and adjust the texture side to all before drawing the wall then all is fine. Quote Link to comment
Jim_Allen Posted October 17, 2008 Author Share Posted October 17, 2008 that was it. I knew it was something simple thanks Quote Link to comment
