Render "Sketch" is default each time drawing is opened
My elevation drawing is "sketchy" each time it is opened, even though it has been saved under Rendering as "No sketch" each time it is closed. How can I set the default to "No Sketch" on this drawing so I don't have to modify it each time I open it? Is there a setting that needs to be changed?
VW2008 Architect SP3, WindowsXP
Well the "no sketch" setting is found under the Render tab of the Object Info Pallette,
But this is not the place you need to make the change.
You just need to go to View-Rendering-Wireframe (or anything other than Sketch for your purposes). Note you can also find these settings in the drop down menu with the little tea pot on it.
Now save it. Close it, and open it again to see if that corrects the problem.
