rebecca21 Posted October 8, 2008 Share Posted October 8, 2008 My elevation drawing is "sketchy" each time it is opened, even though it has been saved under Rendering as "No sketch" each time it is closed. How can I set the default to "No Sketch" on this drawing so I don't have to modify it each time I open it? Is there a setting that needs to be changed? VW2008 Architect SP3, WindowsXP Quote Link to comment
gmm18 Posted October 8, 2008 Share Posted October 8, 2008 Well the "no sketch" setting is found under the Render tab of the Object Info Pallette, But this is not the place you need to make the change. You just need to go to View-Rendering-Wireframe (or anything other than Sketch for your purposes). Note you can also find these settings in the drop down menu with the little tea pot on it. Now save it. Close it, and open it again to see if that corrects the problem. Quote Link to comment
M.CH Posted October 8, 2008 Share Posted October 8, 2008 Note you can also find these settings in the drop down menu with the little tea pot on it. Never noticed the teapot before, must be time for a cuppa!!! Quote Link to comment
