CS1 Posted July 21, 2008 Share Posted July 21, 2008 I have seen the instructions on how to create hatches but im sure it can be made 100X easier. Having the ability to draw what you want and then drag a box over the area to be repeated would be simpler. Quote Link to comment
0 maarten. Posted July 21, 2008 Share Posted July 21, 2008 I would like to agree here, but i'm not going to. The Dutch version has a command that does what you're asking. It works for some hatches, but for others it's very complicated to find the repetition. Also, you'll end up with a lot of layers and that makes your drawing a lot slower. And because you have so much layers, it's really hard to edit the hatch afterwards. So i rarely use that command. I requested this some time ago and i would rather see this actually: Kick out that Create Hatch Dialog And i want to ad to that: Highlight the repetition too when a line is selected. That way it is very clear what you're doing, especially when you're dealing with complex hatches. The options "rotate in wall/symbol" and "by scale" or "scale independend" should be editable by right clicking on the hatch (in the resource browser) and choose the option in the little menu that apears. An extra option to let the line repeats itself "in line" (like it is now) or not. With that option unchecked, we would be able to let lines with an angle repeat theirselves in a horizontal or vertical way. To make myself a little bit more clear, see the image below (the checkbox is not included in the image, i forgot to put it in, but it should be in the OIP): If you would want to make this Roman Tile hatch now, that line would be something like 1000cm long and it would only show 0,01 of it. You would need to do a lot of calculations before you would know the correct vallues. If we could uncheck that option, we could just draw the line the lenght and angle we want it to be, give it it's vertical and horizontal repeating factor and everything is set. This could also be the same workaround for when we would have other objects then lines to use in hatches. And use other terms for the repeating factors, it's way to criptic and hard to remember. So i would rather have colors or so, that's imediatly visible and the change that you'll make mistakes is much smaller. I also want to give the lines and objects a class, that way you can make a very complex Hatch, turn on all the classes in the viewport when you want high detail or turn most of them of when you want low detail hatches. That way you can also use other colors in your viewports for presentation of building plans. Quote Link to comment
0 Jonathan Pickup Posted July 21, 2008 Share Posted July 21, 2008 if you have VectorWorks architect you can draw what you want and use the tile command instead of a hatch. You have to make a symbol of what you want, but it is easier than a hatch. Quote Link to comment
0 CS1 Posted July 23, 2008 Author Share Posted July 23, 2008 Great thanks for that, havent used that "Tile" command before but looks very handy and easy to use. Quote Link to comment
CS1
4 answers to this question
