M.CH Posted September 26, 2008 Share Posted September 26, 2008 Just make sure that you are using the Architect workspace. Alternatively edit your workspace and re-import the pdf option, under Import/export HTH Quote Link to comment
nycL45 Posted September 26, 2008 Share Posted September 26, 2008 I tried the Architect workspace and even reinstalled VW2008. I will try your "re-import the pdf option" suggestion. Thanks for posting, M.CH. Note to NNA: the pdfs I wanted to import last night, and noted in my post above, went out to our client as pdfs and not on our sheets with title blocks. Quote Link to comment
nycL45 Posted September 26, 2008 Share Posted September 26, 2008 M.CH, your suggestion did not work. Import PDF was in the WorkSpace Editor but I deleted it and dragged another over from Commands. It appeared in the list (as it did before). When I clicked it, the same "Plug-in Object file is missing" dialog message popped up Quote Link to comment
M.CH Posted September 26, 2008 Share Posted September 26, 2008 One other thought, if you use preview to open your pdf files and save them with a new name and as pdf, sometimes that will clean up the pdf files. Quote Link to comment
nycL45 Posted September 29, 2008 Share Posted September 29, 2008 (edited) M.CH, I tried saving in Preview with a new name and got the same dialog message. Someone earlier in this thread had noted that there is possibly an Illustrator/VW conflict at the root of this problem. Furthermore, it was suggested that AI be removed. Is there any validity to this theory? NNA and others did not embrace this idea. Edit: BTW, thanks for hanging in there with me on this M.CH. Edited September 29, 2008 by nycL45 Quote Link to comment
M.CH Posted September 29, 2008 Share Posted September 29, 2008 I've got CS2 & CS3 with no problems, I am also running several versions of VW. Did you get the pm? Quote Link to comment
nycL45 Posted September 29, 2008 Share Posted September 29, 2008 Yep on the pm and see my response. I will pm the person who posted the Illustrator suggestion and see if that yields something useful. We are not upgrading to CS or vwA2009 for a while so, if contacting that poster leads no where, I guess no importing of PDFs. Obviously, this problem is not going to be fixed. If there is removing AI is a work around that works I will post that here. Thanks again for your help M.CH. Leonard Quote Link to comment
jfmarch Posted November 11, 2008 Share Posted November 11, 2008 The issue we are having is that the Import PDF... command is not working, as described above, on one of our stations only. It is a iMac, system 10.5, with a slightly modified 'Architect' workspace. This station has the same plugins as the other machines in the office, and it does not have any Acrobat software on it. It does, however have 2 accounts, and we are going to look into seeing if this is causing any conflicts. I did try to add the command in the workspace editor last night, as described above, but that does not accomplish anything. The Import Image File... does work. I even took my working plugins and put them on the unworking station, to no avail. The plugins we have are 'Export PDF (Batch)'; PDFPage'and 'PDFUtilityLib'. Very odd behavior... Quote Link to comment
cad@sggsa Posted November 11, 2008 Share Posted November 11, 2008 Would this not be as result of the machine not having any Acrobat Software. Might be that VW is not reconizing it as a PDF cuase of that?? Quote Link to comment
jfmarch Posted November 11, 2008 Share Posted November 11, 2008 That does not make sense, I think, as we can open PDF's with Preview... Quote Link to comment
jjarchitect Posted December 18, 2008 Share Posted December 18, 2008 I just purchased a new Imac and am having the same problem. I can import pdf files via import image, but I cannot view pdf files in existing vw documents. After several calls with VW tech support and Apple tech support, I have come up with a way to view existing pdf files in existing drawings. I had to create a new account in the systems preferences. Apparently this is a communication problem in accounts. The new account lets me view old files properly. I guess I will continue to use my old account for new work, and switch to the new user account to view old files when necessary. This is not perfect, but at least I don't have to reconstruct hundreds of pdf images, or continue to use my old computer for those situations. This is a very big issue for those of us in Florida who have to import dozens or hundreds of pdf images into our working drawings for required product approval information. Hopefully, VW will be able to come up with a solution. Quote Link to comment
jfmarch Posted December 18, 2008 Share Posted December 18, 2008 Thanks JJ. It does sound complicated and it really should not be for placing PDF's in VW... Quote Link to comment
