Pyrotechnic
Sorting and subtotaling worksheets
I am trying to sort and subtotal my worksheet. I have a record setup that gives me types of signs and I would like the worksheet to give me a total of each sign type. If anyone knows how I can accomplish this please let me know.
I checked out the discussion you posted, but the example in there is in VW 2008. I am still in the previous version so I couldn't check it out. I know how to summarize the worksheet to show what types I have I just can't figure out how to make the worksheet give me a count of how many of each type that I have. If there is a way for me to open your example that would be a great help.
Add a column in the database worksheet. In the database row for that column tpy the formula "=COUNT" (no quotes). That should get you what you are looking for.
Edited by Jeffrey W Ouellette
Although, is there are like a SUMIF function in VectorWorks?
To tackle the issue of subtotaling? Meaning, say I have 3 different uses of areas which are stored under one record field and I want the subtotal for 3 types of AREA on either between database cells or on a separate spreadsheet cell, what should I do?
There is no SumIf function, but you can use the Count outside of the database rows and give it a criteria that will only give you the objects you are looking for something like:
=count('MyRecord'.'MyField'='Type1');
The other option is to split it up and create three different database section one for each type and then do the counts from there.
Yes now I got it to work, thanks Pat, I did;
=AREA('MyRecord'.'MyField'='Type1')
fyi...
Edit #1: Now I'm trying to do
=AREA('MyRecord'.'MyField'≠'Type1')
which ends up in <> signs for exchange with ≠ when you run it.
Any ideas on this one?
Edited by sle7en7
