willofmaine Posted May 9, 2008 Share Posted May 9, 2008 As far as I can tell, the only difference between custom modification and custom selection is that custom modification brings up a new edit properties dialogue box, where as with custom selection modifications can be made in the OIP. Am I missing something? Using custom selection and/or custom modification, I couldn't select windows within symbols (even though I had the box checked). Also, I couldn't seem to make window selections using criteria such as "overall width." Any thoughts would be greatly appreciated! Thanks, Will Quote Link to comment
Pat Stanford Posted May 9, 2008 Share Posted May 9, 2008 The Custom Modification allows you to change objects across layers and classes regardless of the Class and Layer Option settings. After using Custom Selection, you will only be able to modify the objects that are visible. I think you will have problems with entering Field Value is on any dimension fields due to the use of the single and double quoted as unit markers in the US. These are also used as text delimiters in VectorScript and the code generator does not seem to handle them correctly, Pat Quote Link to comment
willofmaine Posted May 10, 2008 Author Share Posted May 10, 2008 Ah, I see (about the difference between custom modification and selection. I remember that, now, from the tutorial CD). Then is the inability to use the Field Value a bug that they are working on to resolve?... Thanks for your response! Quote Link to comment
Pat Stanford Posted May 11, 2008 Share Posted May 11, 2008 I don't know if they are working on it or not. If it is something you want to see fixed, then you should submit it as a bug bugsubmit@nemetschek.net or http://www.nemetschek.net/support/bugsubmit.php Pat Quote Link to comment
