alfresco Posted May 7, 2008 Share Posted May 7, 2008 I have just created a new site plan for a project. I used the property line tool. I have a line coming off the boundary seemily running to infinity. How do I remove this line? It perhaps is an annotation of some kind, but with no end? Quote Link to comment
Jonathan Pickup Posted May 7, 2008 Share Posted May 7, 2008 when I create a property line, i often do not enter the last boundary, instead I let VectorWorks complete the task, using the option to automatically create closing segment. I have a workaround, but it might be quicker to redraw it. A workaround might be turn off the annotations ungroup the property line decompose remove the lines you don't want fix the bad corner select the edges compose objects from polyline make it back into a property line Quote Link to comment
islandmon Posted May 7, 2008 Share Posted May 7, 2008 Ungroup > edit If you're working from survey datum , then be mindful of the exact coordinates and that often the calculated closure is not the survey closure especially with older legacy surveys ( which may have basic rounding errors ). Quote Link to comment
