Brooke Posted March 21, 2008 Share Posted March 21, 2008 Somehow some formerly opaque fills became transparent, so a white fill looked like it was not filled and I spent quite a bit of time trying to figure that one out but assigned another color fill only to find out that it was somewhat transparent. How to fix; how to assign? Atribute palette does not appear to show transparency though it seems it should. Quote Link to comment
Travis Posted March 24, 2008 Share Posted March 24, 2008 Transparency can also be assigned by Class. Check your class setting to see if you have transparency set to something other than 100%. Good luck, Quote Link to comment
Jonathan Pickup Posted March 24, 2008 Share Posted March 24, 2008 in VectorWorks 2008 you can assign transparency from the attribute palette, but not VectorWorks 12. I think it?s layer transparency in VectorWorks 12. So check your layer settings. If anyone wants detailed exercises covering this, it is one of the topics I covered in my online user group last year. if you join the user group, you can see the back issues... Quote Link to comment
Guest Posted March 24, 2008 Share Posted March 24, 2008 It's a setting for the layer - edit the layer and set the "Transfer Mode" to Paint. It's likely set to "Overlay" or "Opacity" Quote Link to comment
Brooke Posted March 25, 2008 Author Share Posted March 25, 2008 Thanks, folks, but no dice. All layers 'transfer' set to 'paint' (that seems a bit obscure to me). Travis, the class setting you mention maybe is only available for 2008? Quote Link to comment
Guest Posted March 26, 2008 Share Posted March 26, 2008 Brooke, Can you take a screen shot and post the image here? Quote Link to comment
Brooke Posted March 28, 2008 Author Share Posted March 28, 2008 I guess so, Katie, what would you like in that image other than a clearly transparent (sur)face with some color to show it is not just unfilled? Maybe an open Org window showing layers set to 'paint'? Quote Link to comment
