CraigCTC Posted March 5, 2008 Share Posted March 5, 2008 We are spending time in trying to create new lighting/accessory symbols that are a little truer to shape and profile. When creating a symbol, I give the symbol a name i.e. "Rosco I-Cue." The symbol is placed in our instrument folder and the name appears correctly in the Resource Browser. However, when the symbol is inserted as an accessory, the text in the "Instrument Type" in the Object Info window reads "S-IV Leko 19 deg." How can I correct it to read as the symbol name without having to retype the text in the Instrument Type field in the Object Info window?? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 7, 2008 Vectorworks, Inc Employee Share Posted March 7, 2008 You need to update the light info record atatched to the symbol def. Edit the symbol and de-select everything. In the Data tab of the OIP enter the new data into the light info record. When you insert a new symbol it will pick up the new information. Quote Link to comment
CraigCTC Posted March 10, 2008 Author Share Posted March 10, 2008 Yes, this works when I try and change an individual fixture - i.e. an I-Cue or DMX Iris. However, when I try and change the light info record for a multi-cell instrument (i.e. an L&E Broad Cyc 3-cell) the info in the OI "Lighting Device" window does not reflect what I just changed in the light info record. In fact, each individual cell that makes up the 3-cell has the correct light info record as does the "whole" symbol. But when placed as an inserted instrument, the OI still lists the incorrect information - S-IV Leko 19 deg. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 11, 2008 Vectorworks, Inc Employee Share Posted March 11, 2008 The information for a multi-circuit symbol is obtained from each cell's symbol def. So if the information on each cell's symbol def is correct it should work. You can send a sample file to tech@nemetschek.net and we will have a look at it. Quote Link to comment
CraigCTC Posted March 14, 2008 Author Share Posted March 14, 2008 I think that might be where the snag was. Each part had different information so it was going to (I'm guessing) some default record. Thanks for the help! Quote Link to comment
