beanus Posted January 4, 2008 Share Posted January 4, 2008 I have trouble selecting callout objects, in version 12.5 I would just drag a box around the callout object & it would be selected now I have to drag a much larger box around them to select them, they seem to occupy a bigger space than is actually shown on screen, also its possible to select them while holding down the Alt key & dragging a box which doesn't even touch the callout object! I've attached a little example just encase its only me that?s getting this little problem. Hope this makes sense. Quote Link to comment
mike m oz Posted January 4, 2008 Share Posted January 4, 2008 beanus, I get similar behaviour. There is also a problem with the bubble shadow option. Quote Link to comment
Seth / MG Posted January 6, 2008 Share Posted January 6, 2008 Have you noticed that when you drag the callouts, the wireframe preview (for lack of a better description) is rotated and not the same size as the text? I suspect this has something to do with it, but so far I have just been reselecting to avoid the callouts, or deselecting them afterwards. Quote Link to comment
