Can VW do this?
Only if 'anyone' can fork over $$ and buy VW (and learn how to use it) is it available.
Erich you are not following.
VW makes QuickTime VR's, which can be played in the FREE QuickTime Player.
That said, the functionality of 3D PDF seems to go somewhat beyond what QTVR has to offer (at least in its current incarnation).
V-G
Edited by VectorGeek
Maybe some VW users have nothing worth protecting but in a competitive market like project building...we do.HTH
Currently, PDF security appears to be notoriously inconsistent and/or easily defeated.
We use PublicKey encrypted server certificates with various access & file permissions.
Files can always we strong encrypted prior to sending.
The Adobe 3D demo/pitch is worth watching all of the way through.
One feature, extreme compression, probably can't be equalled by QT without severe loss of quality.
Maybe this sort of Adobe advance is ultimately good for the consumer; Apple needs to expand the Quicktime basic and pro feature sets. Apple has dumbed down QT a couple of times (that I'm aware of) in quest of the almighty buck with its Pro version. Granted, $30 is a lot cheaper than $995.
I have seen some fantastic 3D PDF work created using Microstation, allowing you to follow a preset "flythrough" animated path, or move through a model on your own independent path, rotate, zoom etc, along with changing rendering, turning on/off layers etc. Of course, that doesn't help the original question :)
