jenn Posted September 12, 2007 Share Posted September 12, 2007 Has anyone figured out how to create multiple room finish schedules within a single file? I have a large file with many room names, different viewports, and sheets, in which the room finish schedule will not fit on a single sheet. Is there a way to break up the room finish schedule to see only the spaces on that particular sheet, and then have an additional schedule on the next sheet showing these spaces? Quote Link to comment
wezelboy Posted September 13, 2007 Share Posted September 13, 2007 When a schedule gets too big for a sheet, I usually duplicate it and then edit the database criteria (by right-clicking on the database header row) to narrow the range of the database- usually by layer. Narrowing it by room number is a possibility also. Sometimes you have to edit the criteria manually though. Word of caution: pretty much anytime you mess with the database criteria in a worksheet, you have to redo the sorting. Quote Link to comment
Archeus Posted September 13, 2007 Share Posted September 13, 2007 Julian Carr's 'Worksheet On Drawing' add-on allows you to split worksheets as well as giving you additional options for formatting them. You can look at it at: . I think it's around $25.00 US and is well worth the cost. HTH! Quote Link to comment
Jeffrey W Ouellette Posted September 13, 2007 Share Posted September 13, 2007 Or, you could create the full schedule on a design layer and then create sheet layer viewports for each portion of the schedule. Simply draw a rectangle around the portion of the schedule you want, leave then rectangle selected, then invoke the "create viewport..." menu command. It should prompt you with a question about wanting to use the selected object as a VP crop. Say Yes and specify the sheet layer you want it to appear on. Lather, Rinse, Repeat.... Quote Link to comment
jenn Posted September 13, 2007 Author Share Posted September 13, 2007 Could you elaborate on this a bit more? Thank you!! Quote Link to comment
wezelboy Posted September 13, 2007 Share Posted September 13, 2007 (edited) I think Jeffrey's method would be easier actually. It would also be better if you needed to change the worksheet format after the fact. If you still want me to elaborate, just let me know what part you are stuck on, and I'll give it a shot. Edited September 13, 2007 by wezelboy Quote Link to comment
