jenn
    6
Reputation
0 Neutral
  1. We have recently been experiencing the problem of not being able to see the door swing and other components of a door symbol when imported to VW from a dwg file. Any ideas on a solution?
  2. We have been able to use the resource browser to see our many worksheets (room finish legends and schedules) in the file. All of a sudden the worksheets are not visible here? What happened?
  3. We are having trouble with changing the space name and its attributes once they are already in the drawing file. Somehow it is changing itself from a space to a plug in object with no edit-able attributes. Anyone know what we are doing or what is going on?
  4. Could you elaborate on this a bit more? Thank you!!
  5. Has anyone figured out how to create multiple room finish schedules within a single file? I have a large file with many room names, different viewports, and sheets, in which the room finish schedule will not fit on a single sheet. Is there a way to break up the room finish schedule to see only the spaces on that particular sheet, and then have an additional schedule on the next sheet showing these spaces?
  6. I am having troubles with my room finish schedule perhaps because its to long. I have a 9-story building, around a hundred room names on each floor. The whole schedule is diplaying on my screen, but when I print the last three floors with the corresponding portion of the schedule, the schedule is not printing. Currently, we are creating viewports around the room finish schedule and cropping it to show the correct rooms corresponding to the finish plan on that sheet. Is there a maximum amount of rooms that can go on a schedule, a better way to do this so the end of the schedule will print, or any other ideas to try?
