Jon W. Posted August 20, 2007 Share Posted August 20, 2007 Well, the answer may be staring me in the face... but hey, it's Monday. I just created a custom title block which otherwise works fine. However, when I was linking text to a record, I ran into a problem with the field type. Specifically: Edit Field > Number > Date > Format > MDY. When I close the "Number Format" window, return to the "Edit Field" window, and select the "Number" radio button, no matter what I type into "Name" or "Default"--the fields will not accept the data. I've typed letters, numbers, etc., but when clicking on "OK", my machine just patiently beeps at me... Anyone have a suggestion? Thanks, Jon 1 Quote Link to comment
islandmon Posted August 21, 2007 Share Posted August 21, 2007 A Date field requires a separator "/" Quote Link to comment
Jon W. Posted August 21, 2007 Author Share Posted August 21, 2007 Tried that--still not working. Very strange... it won't accept input of any sort in the date field. Quote Link to comment
islandmon Posted August 21, 2007 Share Posted August 21, 2007 Edit Field > Number > Date > Format > MDY Shouldn't this read: Edit Field>Date>Date>Format>M/D/Y Quote Link to comment
Jon W. Posted August 22, 2007 Author Share Posted August 22, 2007 No, there is no "Date" radio button. I only have four choices: Integer, Boolean, Test, and Number. When you select 'Number' and go to the Format dialog, you get nine choices, the last being Date. Is your software different? Jon Quote Link to comment
Evan S Posted March 6, 2021 Share Posted March 6, 2021 Coming to this thread all the way from 2021. Having this same issue. Any answers? No matter what I type in the field, It won't let me move on. Quote Link to comment
michaelk Posted March 6, 2021 Share Posted March 6, 2021 There are two valid default value formats (that I know of 😆). When you click on Define and set it to Date, check the format. By default mine is m/d/yy. You need the two slashes (for a date) and the values can't be outside the possible values. So no negative numbers, no zero, no 13th month or 32nd day, etc. You can also use a time value with a colon as a separator. Again, you can't have a 60th minute or a 25 hour. Try 5/5/55 as a default or 1:23. Either of those should work. Quote Link to comment
Evan S Posted March 6, 2021 Share Posted March 6, 2021 So here's what I'm seeing on my end: https://youtu.be/tlz1hgm9Rec Would love if anyone can make sense of it. Quote Link to comment
michaelk Posted March 6, 2021 Share Posted March 6, 2021 I can't quite read what you're typing into the field, (could be the YouTube is still processing the high def and I'm watching standard def) but I assume it's correct. What happens if you try another format? mm/dd/yy or dd/mm/yy? I tried testing a default VW title block. It had the date formatted as text and was resistant to editing. Creating a new field and formatting as a date worked as expected and the date format was editable. Have you tried creating a new field? If that works delete the old one… If nothing works feel free to send a file with your title block. Quote Link to comment
