xxabb Posted August 15, 2007 Share Posted August 15, 2007 Hello everyone, I'm a very freshman of VW with Acad background. Im now using Vw 12.5. Now I'm making a concept design of a 40-floor building. There're many same floors. For eg.,3rd to 13th and 15th to 26th, etc...I firstly use "modle setup" to define the 40 floors and 3 basements. Then drew the 1,2,3 floor...When I finished the 3rd floor,I found I could only copy the total objects of the 3rd floor to the 4th,5th...After I finished the copy, I found there's a little problem with the 3rd, so correct it,and What could do next? do the copy again to see the changed building? What about next time? I have read some topics on net and here, and found no answer. Could anyone help me about this? Maybe sth ridiculous, but it's realy important to me. Thanks a lot. Quote Link to comment
Dieter @ DWorks Posted August 15, 2007 Share Posted August 15, 2007 (edited) just draw the floors that are the same 1 time on a seperate layer, then make a layerlink to that layer on eacht floor layer, fo you would have: layers: floor3-13 (here is the actual drawing of those similar floors) floor3 (layer link from floor3-13) floor4 (layer link again) .... OR you can use a symbol and set that symbol on each layer Edited August 15, 2007 by DWorks 1 Quote Link to comment
mike m oz Posted August 15, 2007 Share Posted August 15, 2007 If the floors really are common try making a Symbol of the first common floor and use it on successive floors. As you update the symbol all of the instances (floors) will update. 1 Quote Link to comment
xxabb Posted August 15, 2007 Author Share Posted August 15, 2007 Dworks and Mike, thank for ur answers the "symbol" is useful, just like "block" in Acad. As "create Layer Linking", there seems not work. I did as Dwork's method and can't get an entire view of the building. Have I done sth wrong? 1 Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted August 15, 2007 Vectorworks, Inc Employee Share Posted August 15, 2007 This is an issue about how you want to present your plans. If your, say, 3rd through 13th floors are absolutely identical, then there's no reason to have unique floor plan sheets for these truly identical floors. (Usually, of course, there are minor differences, if only in the column reinforcing, but this may not affect architectural plans.) You need only draw (and present in plan form) the floor once. But you need multiple copies of this data when constructing an elevation, a visualization model, or a building section. Here's what to do: 1. Create a layer, "Mod-Floor-[3 thru 13]". Draw your actual floor plan elements there. Set the deltaZ of this layer to the height to the next floor. Draw your exterior walls to deltaZ height, your interior walls to (fixed) ceiling heigh, and your columns to whatever height is appropriate (e.g. bottom of slab above, or bottom of beams supporting slab above.) 2. Create layers and draw architectural fabric for all your other unique building floor conditions using the same technique. 3. Create a layer called "Model-Building-3D" or somesuch. On this layer, you create a series of "layer links" which are just like blocks, but instead of having a collection of geometry as its definition, it has a layer in your file as its definition. So, use the "create layer link" command to create a layer link for each of your unique floors. Duplicate repeated floors as necessary. Go to a 3D view (say isometric) and use the 3D cursor to "stack" your floor-blocks. 4. Voila -- you have a complete, dynamically-referenced building model that you can use to create building elevations and sections. Any changes you make to the information in your "floor-" layers will automatically be relfected in your model. Quote Link to comment
xxabb Posted August 21, 2007 Author Share Posted August 21, 2007 Thanks ,Robert. I did as you said and succeeded. sorry for reply late cause my poor router. It had been striking for almost all of last weekend. Quote Link to comment
W4rd Posted January 7, 2019 Share Posted January 7, 2019 @ I was wondering the same. Now it seems layer linking is no longer part of VW. How would you do it now? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted January 7, 2019 Vectorworks, Inc Employee Share Posted January 7, 2019 In "modern" Vectorworks, use a Design Layer Viewport. Quote Link to comment
W4rd Posted January 7, 2019 Share Posted January 7, 2019 I had no idea viewports were also 3D! Thanks! Quote Link to comment
