Daryl Wood Posted February 12, 2007 Share Posted February 12, 2007 in sheet layer viewports. All viewport section layers and classes turned on--no section lines. Quote Link to comment
Mat Caird Posted February 12, 2007 Share Posted February 12, 2007 go to the sheet layer and select the viewport. In the OIP the bottom button is "Section Line Instances" Hit this button and use the drop down at the top of the box to choose "Sheet Layers" Put a tick in the viewport on the sheet layer you wish to see the section line. Be aware that naming your viewports makes this part easier. Mat Quote Link to comment
Daryl Wood Posted February 12, 2007 Author Share Posted February 12, 2007 Thanks for the reply, should that button be below the "Advanced Properties" button? Quote Link to comment
P Retondo Posted February 13, 2007 Share Posted February 13, 2007 Daryl, yes, that button is two below the "advanced properties" button in the OIP. Quote Link to comment
Daryl Wood Posted February 13, 2007 Author Share Posted February 13, 2007 Wierd, for some reason it was not there until I restarted VW. Then the button showed up. Thanks for the feedback. Quote Link to comment
