Daryl Wood
Content Count
190 -
Community Reputation
0 NeutralAbout Daryl Wood
Rank
Journeyman
Personal Information
Occupation
Designer/Builder
Location
Idaho
Recent Profile Visitors
I have a finished VW 2009 design file that giving me the following informational note when trying to use the window tool. In addition, all window data is missing. "A Plug-in Object parameter value is out-of-range due to inappropriate layer scale. Change the scale and try again." I have not change any design layer scales. Has anyone seen this? Regards,
Thank you Michael, it seems to work ok in 2009. Regards,
What is the best way to adjust the highlighted wall face to plane with the adjacent perpendicular wall, in 3D? Regards,
Among other improvements needed, add the capability to show 2D hangers when using custom profiles with either center or solid line display.
Hello Josh, Thanks for the Reply. I realize this is a relatively straight forward script and thought maybe someone had written one I could use without spending the time necessary to write it myself. I just don't want to re-invent the wheel for something like this. It's all about the balance of time, you know. I do, however, feel that it may be worth the time necessary to make something like that as generic as possible in order to easily modify it and use it to quickly populate incremental data. I use a lot of worksheets as schedules in my designs so this would be very useful to me. Thanks for the two links, I'll check them out. Regards,
Has anyone written a script that can loop through a batch of selected objects and insert an incremented field value? With a bunch of walls selected, I need a script that would add a unique and incremented value to the mark field in the "Wall data" record. Anyone done something like this?
Why doesn't this work? Anyone know? =DEG2RAD(FramingMember.pitch) Is it because VW's function interpreter cannot resolve the variable and only works on an real number? I'm trying to build a worksheet formula. Regards,
Thanks Jonathan, I hate it when it's something I've done!
One of my own.
Not working in '09 with the Z key.
Is there a way to reposition the label generated by the framing member tool?
Hi Peter, Here is the file.
I have a large roof face with multiple ridges at different elevations. See attached gif file. One of the ridges thinks it's a square eave. Is there a way to edit this ridge section to return it to a plumb cut, and have the eave remain square?
I am inserting reference markers in a viewport annotation. I would like to make these markers into symbols to use over and over and change the reference in one place, if needed. However, the symbol scales down to the design layer scale, inside the viewport, if edited as a symbol. How can I edit these marker symbols without them scaling down? What am I missing here?
I'm having difficulty snapping to others when I have both layer and class options set to Snap to others. Not sure why, maybe I'm just having a brain spasm. Regards,
