sarah_earney Posted February 8, 2007 Share Posted February 8, 2007 I have one file (a plan of a house as surveyed), which I have referenced into another file, and turned through 90? in order to draw the section as surveyed. Now I want to copy this section file to turn it into the proposed section, so my question is this: is there an easy way of replacing the referenced (survey plan) file with my proposed plan file, in such a way that the layerlink updates too? Otherwise, I have to reference in the proposed plan, then create a layerlink, then turn it by 90? and then make sure it's in the right place... Quote Link to comment
Petri Posted February 8, 2007 Share Posted February 8, 2007 Yes, Sarah, there is. Just replace the old survey file with the new one (ie. put it in the same folder, with the same name). Quote Link to comment
sarah_earney Posted February 9, 2007 Author Share Posted February 9, 2007 Unfortunately that's not feasible - my existing drawings have set names, as do my proposed drawings. It would cause major confusion within the office if I start calling the proposed drawings the same names as the existing. Anyone any other ideas? Quote Link to comment
Petri Posted February 9, 2007 Share Posted February 9, 2007 Was I unclear once again - bummer! No, no: your general approach seems to be just "by the book" so what I thought I was saying will work. Just replace the survey file. Your drawings only know that such a source file lives in such a folder and will read the new file just like that. Quote Link to comment
P Retondo Posted February 9, 2007 Share Posted February 9, 2007 Sarah, Petri has given you the easy way - a clever suggestion - but since it doesn't work with your office standards, I think you are stuck having to reconstruct the reference and link. Only 10 minutes' work, I should think. You could do this: temporarily substitute your new proposed survey for the old by renaming it (= original survey filename), then once you update your reference, your layer link will update. Then, BREAK the reference, which leaves the objects intact in your file. You can then go back to your standard filenames, but you will lose the ability to automatically update the proposed survey info if you change that down the line. Quote Link to comment
eas Posted February 16, 2007 Share Posted February 16, 2007 Go to the workgroup references window, select the file you want to replace and click edit. In the edit window browse to the new file and choose it. The new file will now be referenced into your drawing, replacing the original file. Quote Link to comment
