C. Andrew Dunning Posted February 1, 2007 Share Posted February 1, 2007 Greetings... I am having a problem with Hidden Line rendering losing lines. The problem shows itself where the vertical face of an extrusion meets a horizontal surface and where the vertical face extends beyond the horizontal. This is an example of things "broken:" This is the same drawing with lines added in manually: Is there a fix for this? Thanks! Quote Link to comment
propstuff Posted February 1, 2007 Share Posted February 1, 2007 Andrew, Unfortunately; Not yet................. :-( VW cannot detect where 2 separate solids intersect, only where there are arrises in a single solid. I think it would be a difficult programming exercise, but I hope they get that one fixed soon. N. Quote Link to comment
Jonathan Pickup Posted February 1, 2007 Share Posted February 1, 2007 VectorWorks does not find intersections, if you want these lines you have to stop the objects at the right place Quote Link to comment
C. Andrew Dunning Posted February 1, 2007 Author Share Posted February 1, 2007 Thanks... I guess we all learn something every day about drawing technique. Quote Link to comment
