leave the path when extruding along a path
grant_PD
7 answers to this question
Well....yes. But one of the best features about VW is that 3d objects are derivatives of 2d objects. VW doesn't convert my rectangle into a NURBS curve when I extrude it. I just think it's inconsistent is all. How 'bout we compromise and give me a warning dialog asking me if I want a copy to remain after the conversion.
Generally I'm in favor of maximizing the use of the 2d/3d interface. For an object like a roof, for example, which doesn't preserve the polygon it was generated from, I can see the logic of this kind of request perfectly. Roofs are by nature linked to the horizontal plane. In contrast, an "extrude-along-path" object could, to cite a couple of common examples, be a gutter (strong tie to the horizontal plane), or a stairs handrail (not so easily tied to a horizontal plane), or even an exhaust tailpipe.
Unless the extrude concept were distributed in the interface amongst a series of object-oriented PIOs (e.g., gutter tool, handrail tool), I don't see how the concept could be pragmatically implemented without losing some of the tool's power. The fact that a polygon is automatically converted to a NURBS curve at z=0 when using the extrude tool is a convenient feature, but to ask that the 2d poly be preserved in an edit space because of this convenience is asking the tail to wag the dog. If an extrude-along-path object were generated ONLY in such a way, that would be a different matter.
Granted, I can see the case for creating specific-use tools based on the generalized extrude command that would take advantage of the 2d/3d interface. Which, I admit, is another way of saying what Petri is pointing out.
No, not really. Think about the (hollow) solids. You can go deeper and deeper and finally you find the Unicorn, I mean the 2D object. I'd consider the overall interface of solid operations as a textbook example of simplicity in a very complex series of operations. Me dips me pitfff helmet every time I do them.
Now, if they could also find a way to have something solid inside the solids...
