Zus Posted January 23, 2007 Share Posted January 23, 2007 I am working on my first solo design. I developed the design as a full color concept plan. At this point I want to assign specifics and tags to the plants to make a planting plan. I go in and assign species, etc., but when I go back to the drawing it changes the look of the plants to the default look. I loose the special fills and pen qualities. Help! Quote Link to comment
Jonathan Pickup Posted January 23, 2007 Share Posted January 23, 2007 plant tags should be set up when you make the plants, not later. When you create a plant you decide on the 2D shape, 3D form and plant data. You also choose the tag settings. are you choosing the right bits? Do you need a manual that explains all this in detail? Quote Link to comment
Zus Posted January 23, 2007 Author Share Posted January 23, 2007 I thought that you could place plants first and then go back in later and edit the plants. Quote Link to comment
Jonathan Pickup Posted January 24, 2007 Share Posted January 24, 2007 you can, but it?s better to make the plants and then place them. Best of all, make your plants in a library so that you can use them on every job... Quote Link to comment
Petri Posted January 25, 2007 Share Posted January 25, 2007 By the way, I'd like to be able to have tags without a leader line, positioned next to the trunk cross. There are few occasions when the tag needs to be somewhere else. Quote Link to comment
