Jim_Allen Posted February 26, 2006 Share Posted February 26, 2006 Does anyone know how to set up a lable legend for an instrument that is not facing upstage or down stage??? I am trying to set up a sidelight instrument and CANNOT figure out how to align the information blocks so they will be in front of the instrument. Something has changed in this menu from previous versions!!! Figuring out this program is mind numbing!!!!! Quote Link to comment
Steve B. Posted February 27, 2006 Share Posted February 27, 2006 Create a new label legend for side lights When editing in the label legend manager, rotate the instrument in the direction the unit focuses (as well as using the correct symbol for the light), then place your attributes wherever you want them. It takes a few tries to get all the attribute placements correct on the drawing. You might want to create a SR separately from a SL, ditto a different label for a PAR vs. an S4. I find it easy to create a SR then do a Duplicate in the resource browser, then go in and rotate horizontal for the new SL label, as example. SB Quote Link to comment
C Dopher Posted March 20, 2006 Share Posted March 20, 2006 I made my sidelights label legend in one shot; since the legends rotate with the units at or after placement, it was no big deal to make a sidelight legend by simply avoiding an imaginary VERTICAL line running through the sample instrument. Later it may be necessary on a few units to manually drag the information around to be more presentable. I find this feature to be VERY useful! Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 20, 2006 Vectorworks, Inc Employee Share Posted March 20, 2006 If you place a label in front of the instrument it should always appear in front of the instrument. If it is not doing this, please submit the problem to bugsubmit@nemetschek.net. It should work as the same as previous versions. It should not be necessary, nor is it advisable, to rotate the instrument in the lable legend manager. This will only cause the labels to be placed at odd positions around the instrument. Quote Link to comment
Jim_Allen Posted March 23, 2006 Author Share Posted March 23, 2006 Kevin, Can I email you this plot so you can see what I had to do, and verify if this is a bug or not. Take a look at instrument #1 on the # 4 elect and then SL in the Label Legend Manager to see what I did. Also would like you to look at the key - look at what is happening to the strips, and instrument names. Jim Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 23, 2006 Vectorworks, Inc Employee Share Posted March 23, 2006 Send it to me directly (if you still have my email adress) or send it to tech@nemetschek.net to my attention. Quote Link to comment
Jim_Allen Posted March 24, 2006 Author Share Posted March 24, 2006 Don't have yours - but it was sent to tech ATT: you Thanks Jim Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 24, 2006 Vectorworks, Inc Employee Share Posted March 24, 2006 Jim, The Purpose is set to not be right reading, and rotated 90 in the LL. When which means that the text rotates with the instrument. So the instrument is rotated 90, the Purpose text is rotated 90. Where as the Color is set to Right Reading, so even though the instrument is rotated at 90, the text maintains its original rotation. If you are trying to get the information to always appear upstage or downstage of the instrument, that's different. The spacing problem is a know issue with the instrument key. The Key is a simple group that you can edit to rearrange the information. Quote Link to comment
Jim_Allen Posted March 25, 2006 Author Share Posted March 25, 2006 Kevin, What I am trying to do is when I have sidelights the color and purpose text appears in front of the instrument orientated the same as instruments facing up/dn stage. I am not sure I understand your explanation. Why would purpose and color not orientate the same way?? I assume we all want the text information orentated the same reguardless of which way the instrument is facing, so the ME doesn't have to turn the plot in circles to read?? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 27, 2006 Vectorworks, Inc Employee Share Posted March 27, 2006 Open the label legend manager. Select the Purpose field, notice that the right reading check box is checked. Select the color, notice that right reading is checked. This is why the Purpose label and the color label act differently. Quote Link to comment
