text along path...VW 12
I am trying to put text on the outside of a circle, so that the bottom of the letters are 'sitting' on the outside of the circle. I can only get the text to wrap around the inside of the circle, with the top of the text touching the inside of the circle. Just a bit baffled. I can not find the parameters to change this....
Use Duplicate Array around a center point (use a circle as a guide) with a letter that you make a symbol with the bottom of the symbol touching the center point of the the symbol origin. circletext.JPG
Don't forget to turn the text into a poly before making it a symbol this way it will orient properly around the circle.
Pete A.
There is a movie showing how to do this in the VW12 Demo movies:
http://www.nemetschek.net/training/library.php?movie=12movies
New Text Along Path Command
With the new Text Along Path command, you?ll be able to create 3D text objects that follow the path of a curve.
There are also a couple of movies in the Location Planning movies section which may be of interest:
http://www.nemetschek.net/training/library.php?movie=LPmovies
Edited by mike m oz
Thanks all. I will look at the vw 12 demo movies. I got it to work on a polyline curve, but will not work how I want it to on a circle or arc. The bottom of the text will still only attach to the inside of the circle. I will do the upgrade to 12.5 and see if I have any more luck...thanks again all...the cantor
On my setup, it defaults to the inside of the arc/circle. The bottom of the text is on the arc.
1. In the OIP, I change Rotate about Path to 180 deg. It is now on the outside, but backwards.
2. Use Modify>Rotate>Flip Horizontal. It now reads correctly.
3. Now you can rotate to the desired orientation around the center of the arc.
George
