The Cantor
Content Count
78 -
Community Reputation
0 NeutralAbout The Cantor
Rank
Apprentice
Personal Information
Occupation
Tech.Director/Draftsman
Location
Missouri
Recent Profile Visitors
Stage Lift is hanging and crashing VW 2019
The Cantor replied to The Cantor's topic in Entertainment
So... I edited the current workspace, deleted the icon, replaced from the left side, and now it's happy. time for a beer! -
Anyone else having issues with the stage lift that came with Spotlight 2019? I have forced quit and reopened several times. Just high-lighting the object causes the spinning ball of death. 2017 Mac Pro/Mohave/32GB
VW hung even on a new/clean empty Spotlight file. Restarted VW 2019 opened new Spotlight template created a rectangle created second rectangle, to use to create viewport on new sheet layer double-clicked on the auto-created annotation showing the scale of the viewport spinning hanging ball appears. Screenshot of top of the report sent to Apple is attached. HELP...
Still happens with OIP undocked. In fact, I always have it undocked.
Same issue. Hanging when attempting to make annotations in viewport in sheet layer.Mohave 10.14 Model Name: iMac Pro 2017 Radeon Pro Vega 56 8176 MB Model Identifier: iMacPro1,1 Processor Name: Intel Xeon W Processor Speed: 3.2 GHz Number of Processors: 1 Total Number of Cores: 8 L2 Cache (per Core): 1 MB L3 Cache: 11 MB Memory: 32 GB Boot ROM Version: 220.220.102.0.0 (iBridge: 16.16.1065.0.0,0) Yes, I can reproduce. Spinning ball. file is attached. Valentus.vwx
Add Text Size to Dimension Line OIP
The Cantor posted a question in Wishlist - Feature and Content Requests
Would appreciate the ability to change font size in the OIP of dimension lines, instead of having to run all the way up to the Menu bar to make the revision. Having font size visible in the OIP would also save some strokes by knowing at a glance what size is existing. -
This is a new one on me. Unless I have an object high-lighted when changing views, simple views...iso left or front elev or rear iso...I just get a pinkish color on the screen, along with a thin red vertical line. I had imported a ballroom file that had some 2D as well as 2D/3D walls. Did I turn some thing on or off or is the file just bad? I also tried to copy the contents into a clean empty file, and same results. And of course, I lost about 3 hours of work when the file and the backup decided to delete all of the scenery and trussing I made. very frustrating...
Font Size in OIP for Dimensions
Please add the ability to change font size in the OIP for dimensions. I waste a lot of time having to go up the Text menu vs. simply going to the oip and changing there. Please! -
chandelier shaped like an egg split in half
The Cantor replied to The Cantor's topic in General Discussion
Thank you all for your help. -
I ended up making oval/split/sweep/subtract solid. Worked well. See image. -
Maybe it's too late for me to think straight, but how can I make a shape that is basically an oval, swept 360 degrees, so I can then split in half? I have a chandelier I am trying to recreate that looks like an egg split in half along long axis.HELP!
Thanks. I thought I had tried that, but had not. I forgot to check the 'Set Vectorworks units to match'.
I received dwg files that will not import in scale correctly. I have tried my normal methods of work-a-rounds, but not having any luck. Metric files. I have attached one of the files, along with a pdf. I would appreciate it if someone can scale it correctly, but more importantly, share what you did to correctly scale it. Imac Retina 27", VW 2016. Thanks!
Blended screen OIP will not allow rigged projectors
Thanks. Changing in projectors makes sense. -
It will work, but I have to close and reopen Vectorworks. This is taking a lot of time and very frustrating. Hope someone checks into the issue.
