marek.dk Posted September 21, 2006 Share Posted September 21, 2006 does anybody know how to make a line of dots? would be nice to have a dot line as a dash style. I was trying the dash style editing but I couldn?t get a satisfying result. Any ideas? Quote Link to comment
Ken Posted September 21, 2006 Share Posted September 21, 2006 Here's one idea: Use the Duplicate Along Path tool. You'll have to determine the size and spacing of your dots. For example, create a circle with diameter of 1 inch, lineweight 1mm. Press Option-P to call the tool. Press U to set mode to Draw Polygon, press I and set prefs for fixed distance at 4". Draw your line of dots, double-click to end. Quote Link to comment
marek.dk Posted September 22, 2006 Author Share Posted September 22, 2006 thanks for the idea. But this way I will get many objects instead of one editable line of dots. Quote Link to comment
islandmon Posted September 22, 2006 Share Posted September 22, 2006 Take a look at the Font> "Wingdings" ... very useful for many situations many key combination options. Quote Link to comment
bryn Posted September 22, 2006 Share Posted September 22, 2006 Select File > Document Settings > Dash Styles. Add a new style and carefully adjust the sliders to get your req'd dot pattern. Leave the "scale with line thickness" box checked. bryn Quote Link to comment
rDesign Posted September 22, 2006 Share Posted September 22, 2006 Try the Repetitive Unit tool. You'll have to make your own 'dot' to use as the selected symbol. The folder located in ~Vectorworks/Libraries/Default/Repetitive Unit/Miscellaneous has a file of some ready made symbols (including 'footsteps' ?). Make your 'dot' symbol in that file so you can easily use it later. On the PIO you can control the dot spacing in the 'Pitch' box, uncheck the 'Use Symbol Pitch'. To change the dot size you'll have to go back to the original in the Misc Symbols file. You can also have the dot line have a centerline or not by changing the linetype style. Hope that helps. Regards, Tim Quote Link to comment
