propstuff Posted July 15, 2006 Share Posted July 15, 2006 I seem to recall a discussion on this but I couldn't find it; so... I setup a perspective saved view as desired. I made a viewport of it to place on a sheet layer. The view in the viewport had nothing to do with what I had set. The perspective was different, the view angle was different. The view distance was different. All so different that I couldn't get it back to where I wanted it. Yet I just did it on another file and it worked. Is this something to do with location from origins and ground planes?? So how do I get my saved view as a Viewport? N. Quote Link to comment
mike m oz Posted July 15, 2006 Share Posted July 15, 2006 (edited) Nicholas, have a look at this thread: http://techboard.nemetschek.net/ubbthreads/showflat.php?Cat=0&Board=UBB17&Number=62373 Edited July 15, 2006 by mike m oz Quote Link to comment
propstuff Posted July 15, 2006 Author Share Posted July 15, 2006 Hi again Mike That was probably the thread I was thinking of, but it doesn't help me much. The file in question on thursday had only one layer displaying (not linked etc). I had the view I wanted, but when I did your Step 2 was when it all went wrong. I made the view port of my perpective view, but what showed in the viewport had nothing to do with the view in the Design Layer. (??) Quote Link to comment
mike m oz Posted July 15, 2006 Share Posted July 15, 2006 (edited) Nicholas - I tried it with a view when the Z of the layer you are viewing from is not zero. What it appears to do is put the view point at the layer Z height and the object at the absolute zero Z height. (I think you have caught them out with something they didn't anticipate). - You can adjust the viewing height by double clicking on the Viewport and choosing to edit the crop. Use the Walkthrough Tool to adjust the height you are viewing from (Raise Ground Plane Mode and Lower Ground Plane Mode). The other option is to adjust the Z height of your layer to zero (you could try layer linking to a layer with a zero Z height). Edited July 15, 2006 by mike m oz Quote Link to comment
propstuff Posted July 15, 2006 Author Share Posted July 15, 2006 I just tried that, and, yep, that appears to be it Mike. When I get back on tuesday I'll check the file in question and see if that's the case. cheers, N. Quote Link to comment
