tlandis Posted June 29, 2006 Share Posted June 29, 2006 I want to put "x" lines on the ends of boards I have in a drawing while viewing from the front, but when I click on the detail object my view changes to Top/Plan. Can you tell me how to get these details on board ends? (I'm using VW 11.5) Thank you! - Tod Landis Quote Link to comment
Travis Posted June 29, 2006 Share Posted June 29, 2006 The wood cut detail tool is 2D only, which forces the drawing to the 2D "view" to place objects. But, no worries. . . when the drawing switches, go ahead and place the cut detail. Then switch back to Front (Side, or whatever) and locate the detail where you want it. As an aside, I use the wood cut detail a great deal but nearly always in the Viewport rather than on the Design Layer. There's no perspective shifting and they're easy to move if the design gets revised. Good luck, Quote Link to comment
tlandis Posted July 1, 2006 Author Share Posted July 1, 2006 Thanks Travis... I want the x end details to show up in an isometric view,too, so I ended up using the 2d line tool to snap the detail lines to the corners of the board ends on each of the views. - Tod Quote Link to comment
mike m oz Posted July 2, 2006 Share Posted July 2, 2006 (edited) tlandis, two solutions: - Draw the X in a 2D elevation view and then with both lines selected convert them to 3D polygons. This 3D X can then be placed manually in position. (If you have lots of them turn it into a symbol first.) - Draw your board cross section in a 2D elevation view and include the X. Select the shape and the X and extrude both of them in one operation. The X will show in all linework rendered views, but not in renderd Open GL or Renderworks views. (Once again if you have lots of them make the board a symbol.) Edited July 2, 2006 by mike m oz Quote Link to comment
