Hugo Posted May 17, 2006 Share Posted May 17, 2006 Hello. I am inserting doors in VW 12, in a wall, and the door appears in the wall and in the floor. I have changed several settings but it is still on the floor. How can I convert it to a normal door? Thank you. Quote Link to comment
Kaare Baekgaard Posted May 18, 2006 Share Posted May 18, 2006 I suupose, you've changed the height setting from 0 to something else? (the very first numerical input in the object info palette) Quote Link to comment
Robert Anderson Posted May 18, 2006 Share Posted May 18, 2006 Is this door using a custom slab? Quote Link to comment
bclydeb Posted June 14, 2006 Share Posted June 14, 2006 As a trainer I get this question from trainee firms which are experiencing it. I had it occur in one of my files as well but I cannot recall how I actually solved it. (mostly by random poking) Has this issue been resolved? Quote Link to comment
bclydeb Posted June 14, 2006 Share Posted June 14, 2006 I found what I takes to resolve the problem. In the door dialog sets where you input the door thickness - if the thickness for the door is zero (0) the floor "shadow" shows up. To be sure your door is at a real thickness go to Door Tool>Door preferences>parts>Part:Leaf (drop down) and set the thickness to a positive thickness. Thin doors are possible but not zero thickness. Quote Link to comment
Robert Anderson Posted June 14, 2006 Share Posted June 14, 2006 Look for this bug to be fixed in an upcoming relesae. Quote Link to comment
Hugo Posted October 4, 2006 Author Share Posted October 4, 2006 The problem is happening to me again and I can?t get rid of it... How can I get back my normal doors? Thank you Quote Link to comment
Hugo Posted October 4, 2006 Author Share Posted October 4, 2006 Just discovered that if I choose "glass" as the leaf type this happens, and if I return the leaf back to "solid" it disappears. Why a glass door has to appear duplicated on the floor? Quote Link to comment
Hugo Posted May 16, 2007 Author Share Posted May 16, 2007 Any input on this problem? Quote Link to comment
Guest Posted May 17, 2007 Share Posted May 17, 2007 Send a file and all this info to tech@nemetschek.net AND bugsubmit@nemetschek.net Quote Link to comment
Cris with no H Posted May 18, 2007 Share Posted May 18, 2007 A similar problem with Window sills extending out was fixed by turning off Quartz. Cris Dopher Quote Link to comment
