Chris Fleming
Batch printing problems
Mac OS 10.3.6 printing to a laser printer (Gestetner 3227) via Ethernet connection. Using VW 11.0.1
When batch printing saved views. It will print the first view only. For instance, if I have 16 saved views I need to print, I select the batch print command and make sure all the saved views are checked to be printed. One copy each. Instead I get 16 copies of my first saved view. This is 100% repeatable. The only way for me to print the other saved views is to print them one at a time.
The number of copies of my first saved view is always equal to the number of saved views I'm printing.
Help!
4 answers to this question
No. I use different names for all views (floor plan, elevation a, elevation b, mechanical, etc.)
I might have some design layers with the same name as a saved view (mechanical as a design layer, and mechanical as a saved view). However, since I select the design and sheet layers that I want visible during the save view process, I don't see how that would affect anything. But I'm definitely open to any possibilites.
Thanks,
Chris
Do you have saved views, design layers or sheet layers with the same names?
[ 01-07-2005, 12:39 PM: Message edited by: klinzey ]
Try renaming the sheets and saved views differnetly. There is a bug in 11 with batch print that accures when you have layers named the same as a saved sheet.
