Henry_SRL Posted May 8 Share Posted May 8 (edited) Hi there, I have created some walls using the Wall Tool and am trying to apply a renderworks texture to it. However, only the perimeter faces have the texture applied. In the Object Info - Render palette, a lot of settings that I'm used to seeing are now missing: The first image on the left is what my coworker sees, and what I'm used to seeing; a dropdown of applying textures to the overall or to specific faces. I, on the other hand, am experiencing the second image on the right, which is missing this whole dropdown entirely. I'm unsure if there was a setting that got changed or something, but we just recently upgraded our hardware at our office and have a fresh install of Vectorworks, and this has only started to become an issue with the new computer I'm operating on. Thank you! Edited May 8 by Henry_SRL Image attached twice Quote Link to comment
Cody Worthman Posted May 8 Share Posted May 8 The wall your coworker has selected isn’t the same wall style as selected in your file, is it? I can’t tell you why you’re not seeing the same by face/by object options, but try editing the wall style, going to the texture tab, and select the same texture for each part, or set the overall texture then select each part and revert to overall. Quote Link to comment
Popular Post Tom W. Posted May 9 Popular Post Share Posted May 9 Bit of a long shot but is it possible the parts-of-the-Wall section of the OIP has become collapsed + needs re-expanding...? Can you drag down on red line?: I am on not on Windows so can't check if it's possible to completely hide it in this way (it isn't on Mac). Otherwise I have never seen this pane disappear before. 5 Quote Link to comment
Henry_SRL Posted May 9 Author Share Posted May 9 @Tom W. Your long shot was 100% correct, it was just collapsed 🤦♂️ Thank you so much! 1 Quote Link to comment
