Cody Worthman
17 -
Everything posted by Cody Worthman
Candy cane stripe around Hardscape object
Cody Worthman replied to Cody Worthman's question in Troubleshooting
This isn’t in a viewport, it’s directly around the hardscape object in the design layer. -
How do I turn off the candy cane stripe? It's not related to updating the site model. I unchecked show slope A. & slope B, but I am still getting the box around the object.
Content request - Decks coffee break
Cody Worthman posted a question in Wishlist - Feature and Content Requests
I've seen quite a bit of material about hardscapes, which is quite a broad topic, but nothing specifically pertaining to decks. I would love to see a coffee break session or series of sessions about designing decks in landmark. `Quite a broad topic in itself, but it's a common element for landscape architects and designers, and I've seen a wide variety of recommendations involving a wide range of tools and commands depending on what you need: -floors, slabs, hardscapes -framing members, create joists, structural member (not available in landmark) -railing tool -stair tool --curtain wall (not available in landmark?) for deck skirting -wall tool for foundation walls + other stuff, columns for piers, drilled footing (not available in landmark -roofs -extrudes (I feel like I rely too heavily on this tool, and end up missing out on some of the benefits of vwx Is there a workflow we should be use if we need all of the following from the same file: -an accurate model for 3d rendering in Vectorworks but also Twinmotion, lumion, etc -framing plans, cut lists, and material lists -
Ive been wondering how my deck workflow compares to others, but it looks like I stumbled upon a similar solution as others have. I’ve been using hardscape type decks as temporary placeholders, then modeling all the elements (starting with the decking) once all the design details have been decided upon. The hardscape helps establish the decking surface elevation and material choice (and overall deck shape). I treat stairs similarly, using the stair tool for design decisions but modeling each element as the design progresses. I would love to see a coffee break session about decks, as I don’t think I’ve seen them used in any of the vwx tutorials yet. It seems like they’re important features for landscape & architectural design. I’ve mostly watched site design tutorials, so maybe I should watch more architecture videos to better understand their workflows.
Yeah..I feel like I can make my own image props. I'm wondering if its possible to purchase the high-poly, and create a copy in Vectorworks and simplify the mesh so its not as laggy. Not sure if that's possible, but I might have to purchase some and see if it works out.
2024- sp4 Edit Subdivision Tool creating incorrect geometry
Thank you! That was it. -
Cody Worthman posted a question in Troubleshooting
No matter which render setting or graphics quality I use, my edit subdivision tool creates incorrect geometry. My circle shows up as a square; cylinders and spheres as cubes, and the torus & ring are both very faceted despite being my settings being on Very High. Aside from split & extrude mode, I can't do any other manipulation of the incorrect geometry. Even on the geometry that was produced properly, the crease mode does not work. Any advice? -
Ben, hope you don’t mind me reviving the this thread with a question. Are those low poly or high poly globe plants? I’m looking to purchase a few collections of globe plants for use in both twinmotion & vwx, and was wondering whether they were low or high poly, and which file format you downloaded as it appears they have multiple formats to purchase.
I recommend taking the Landmark professional certification course. That course goes over importing topographic surveys & existing tree surveys. You then learn how to use most of the landmark tools on a large mixed use site (has commercial & residential properties.) It goes more in depth than the basic landmark essentials class and the only thing it doesn’t cover is viewports/sheet layers for producing design documents. It’s very helpful for understanding how many of the tools interact with the site model.
Deform tools issue - Freeform modeling (skatepark videos) -
I was trying to use the methods show in the video series, but thanks for the workaround idea. Not sure why the deform tool was skewing the rail in 2024. I tried the same process in 2023, and it worked perfectly. 2024 crashed on me several times yesterday: I'm not technical, but I'm wondering if it is an installation issue. Attempting a reinstall, and hoping for the best. Jeff, I was able to perfectly recreate the drawing in 2023 and I used the same basic process: I found the center point of the rail, and clicked there to establish the working plane. Then used the hemisphere tool on diameter mode and clicked from one edge to another. For some reason 2024 was skewing the shape of the pipe when using the deform tool. After the first deform and I lose the ability to snap to any sort of smart point within the geometry. I tried toggling all my snapping cues off and back on, hoping it would detect the points again, but it didn't help. I've tried executing the deform with different views (relative to working plane, relative to layer plane) and I still lose all snapping ability after the first bend. After restarting my computer, I was able to execute a bent rail on 2024 that wasn't skewed and I was able to use the hemisphere tool to make a perfect fitting end cap. However, a few minutes afterwards the program crashed and upon restarting the rail skewing returned. My best guess is that I had an installation issue, although it could be that my outdated MacBook Pro (pre-M series) is no longer able to meet the system demands. -
Running into issues using the deform tool to replicate the curved rail in the skatepark/freeform modeling series of videos. The video is quite old, and I'm using 2024 to recreate the project. 1. Once I've used the deform tool on one portion of the rail, I am no longer able to get a smart point/centerline for the 2nd & 3rd bends. The centerline is able to be used for the first bend. (I'm using the Bend solid & Finite mode as seen in the videos) 2. When using the hemisphere tool to create rail ends, the rounded portions do not match the shape of the rail. The deform tool may have changed the rail profile from circle to a skewed rounded shape. (two screenshot attached-the rail that had less bend seemed to better match up with the hemisphere which is why I believe the deform tool is changing the overall shape of the rail). Is there something I've messed up along the way or has there been some changes to the deform tool? How can I make my drawings more accurate. -
Howdy, This is not the first time I've had issues with discrepancies when following along with tutorials, but I cannot figure this one out. I'm on the "Cutting holes in the slabs" portion of the small residential model section, of the intermediate concepts course. Around the 10:40 mark of the video, the instructor changes the textures of the floor assembly but I'm not able to recreate it. There are a couple differences between 2019 & 2022 workspaces that have been problems in previous tutorials and learning paths, so I'm hoping y'all can assist me so I can solve my own problems in the future. In 2019, the plywood decking is in the component-decking class, but in 2022 its in the component-structure class (component-decking doesn't exist). Not sure if it matters, but 2022 also has a materials column that doesn't exist in 2019 workspace. The instructor then goes on to edit the class' texture, which changes the appearance of the plywood to that of a hardwood. Whenever I attempt the same, (remember, mine is only in the component-structure not component-decking) the appearance does not change. It's still the same OSB appearance. Is there something that has changed between 2019 & 2022, possibly related to the materials that would prevent the change from happening?
Apple macOS 12 Monterey Compatibility - Feedback
Cody Worthman replied to JuanP's topic in News You Need
Since updating to Monterey with vw 2022, I’m having issues with using the “Z” key to zoom. When I use the “z” key, the box that shows the magnified area is completely blank/void of line work and essentially useless. -
Resource Manager - there are no items to show in this view
Thank you! That was about to make me pull my hair out. Wishlist topic has been upvoted. -
My resource manager show all the different file folders that might contain hatches, gradients, symbols, objects, etc. When I try to click the files, it says "there are no items in this view". This is for both Premium & Vectorworks libraries. I'm able to access the missing files through the attributes palette, but not able to through the resource manager. Can you recommend a way to fix this? Uninstall and Reinstall libraries?
