Gal Posted March 20 Share Posted March 20 Hello everyone, Is there a way to insert a symbol such as a recessed light fixture into a slab while making a hole in it as with walls? Gal Quote Link to comment
Tom W. Posted March 20 Share Posted March 20 6 minutes ago, Gal said: Hello everyone, Is there a way to insert a symbol such as a recessed light fixture into a slab while making a hole in it as with walls? Gal Yes. Using the 'Add 3D Object to Slab...' command. The symbol doesn't need to have 'Insert in Walls' enabled. Include a Wall Hole Component in the normal way if required. The only issue is that Data Tags don't 'see' the symbol once it becomes a Slab Modifier. Bit like skylight symbols added to Roofs. 1 Quote Link to comment
