I dont get this AI to work
So i have tested a bit, and everything i do ends up with some or most of the image in neon colors. And i did a simple test. I gave VW AI the same image as i gave ChatGPT DallE with the instruction: "fill this image with a rock and roll show". See images bellow for results.
I understand that good instructions is the key here and those might bee somewhat secret or personal, but i do not understand why Vectorworks cannot share the instructions for each and every successful AI image they get and post as PR. Clearly I'm doing something wrong. 🙂
Original image:
VW AI(25% creativity):
DallE:
22 minutes ago, grant_PD said:
Also a little disappointed that your image you gave to DallE looks nothing like the end result.  Both are fails in my opinion.
O, i absolutely agree, but there is with DallE a constant 100% creativity unless you are more specific in your description. So, based on the input, I would say that DallE gives way better results. VW AI is unusable in this case.
