Stefan B. Posted March 14 Share Posted March 14 So i have tested a bit, and everything i do ends up with some or most of the image in neon colors. And i did a simple test. I gave VW AI the same image as i gave ChatGPT DallE with the instruction: "fill this image with a rock and roll show". See images bellow for results. I understand that good instructions is the key here and those might bee somewhat secret or personal, but i do not understand why Vectorworks cannot share the instructions for each and every successful AI image they get and post as PR. Clearly I'm doing something wrong. 🙂 Original image: VW AI(25% creativity): DallE: 1 Quote Link to comment
grant_PD Posted March 14 Share Posted March 14 Also a little disappointed that your image you gave to DallE looks nothing like the end result. Both are fails in my opinion. 1 Quote Link to comment
Stefan B. Posted March 14 Author Share Posted March 14 22 minutes ago, grant_PD said: Also a little disappointed that your image you gave to DallE looks nothing like the end result. Both are fails in my opinion. O, i absolutely agree, but there is with DallE a constant 100% creativity unless you are more specific in your description. So, based on the input, I would say that DallE gives way better results. VW AI is unusable in this case. Quote Link to comment
Vectorworks, Inc Employee Popular Post Dave Donley Posted March 14 Vectorworks, Inc Employee Popular Post Share Posted March 14 Turn off Draw Edges in the Shaded rendering. And/or try adding the words "edges", "lines", "neon" to the negative prompt. Pixel color and brightness differences are detected and turned into an image of the edges found. The extra edginess in a Shaded with draw edges on or in a hidden line rendering can cause this glowing edges result. For a prompt you might try being more specific to help the AI understand what it is seeing and what style you are wanting. Like a caption for a photograph. Hope this helps! 6 Quote Link to comment
grant_PD Posted March 14 Share Posted March 14 @Dave Donley that's a big improvement, and really helpful info! 1 Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted March 15 Vectorworks, Inc Employee Share Posted March 15 3 1 Quote Link to comment
