U-Torm Hoist Attachments
Hi Luke, The issue is the symbol. For some reason, it was built vertically instead of horizontally. While I don't know when Global Truss might make an updated symbol, here's a video showing how to make the changes needed for this top bar. I've also attached the file in which I made the changes. You'll need to do the edits to the other symbols as well.
U-Torm Test.vwx
Posted (edited)
Cheers,
Thanks so much for the detailed walk-through, though now each section only wants to join side by side, is there a fix for this other than @jcogdell's? Would prefer to keep it simple stupid and just edit all of them so that they are all vertical.
Edited by Luke Wyn-Harris
Extra question
You can edit the symbol and it should update all the copies. You might need to exchange them though. It's the same process as I showed in the video when I edited the top bar.
Yes the main difference is you need to define the hanging bar as a T-corner in the Truss properties dialogue (accessed from the right click context menu) and then add the magnet locations using the XYZ fields.
  • 5 weeks later...
So, I followed the video above, which was very helpful, but I still have some issues.
1. The top part and the ladder will connect correctly, but they will not join to be the same system object.
2. I can't do Insert drop between a regular truss and the top or the ladder
Any help will be appreciated
