EDIT for clarity: I use the field/record terminology for tabular data as commonly used in GIS applications. When I use the term "record" I am referring to what would be called a "row" on a spreadsheet or an "observation" in other data related disciplines. I am not referring to VW resource records.
When prompted to add a new or edited plant style to the catalog, VW will interpret some of the data as new records (or rows) from the values in each field. The pattern I have been able to determine is some hidden delimiter in the data that ships from one of the Vectorworks catalogs. When I create plant data from scratch I am able to import and export between catalogs without issue. As an example, here are some screenshots from one plant edited in the VW2008 catalog. I have edited the flower characteristics, tolerances, and comments fields. It seems when there are multiple values delimited by a space in the same field, VW will interpret as a new record. If I include a pipe (|) VW for read as multiple values. This is not user-friendly.
Please do not reply with advice for using plant styles in their own drawings or to avoid use of the plant catalog. I am already familiar with these approaches.
Peter W Flint
2 answers to this question
