lucid.lx Posted February 14 Share Posted February 14 I recently received a DWG file from a scenic company for an event. I need to show the client some lighting examples in the room but the scenic drawing i received is only a frame. At the event there will be a fabric material stretched over the frame - is there a way to accomplish this within Vectorworks ? Any direction / support would be greatly appreciated. Quote Link to comment
Jeff Prince Posted February 15 Share Posted February 15 You could do it pretty quickly with the wall tool. Outside components as fabric, inside component as air gap. That would do both sides at once without obscuring the frame. Alternatively, you could draw polygons and extrude them in 3D views pretty fast. Quote Link to comment
EAlexander Posted February 16 Share Posted February 16 I would let go of the idea of wrapping and just draw polygons on the downstage face to match your frame silhouette and extrude them 1/16" as Jeff has suggested. 2 Quote Link to comment
BartHays Posted February 18 Share Posted February 18 And/or draw the downstage polygons and use Convert to Surface to eliminate the extra geometry while still allowing for textures. You may want to move .03" off the frame to avoid "z-fighting" 1 Quote Link to comment
