Zsombor Posted February 1 Share Posted February 1 I asked AI to write me a script with the function named in the topic. It gave me this, but it doesn't work. I'm an outsider, what do you think, is it a mess or are there just some small bugs in it? PROCEDURE SelectTextObjects; VAR worksheet : HANDLE; num_rows : INTEGER; row : INTEGER; cell_data : STRING; text_objects : ARRAY[1..1000] OF HANDLE; i : INTEGER; BEGIN { Get the active worksheet } worksheet := GetWSByName('hrsz'); { Get the number of rows in column A of the worksheet } num_rows := GetWSCellNumRows(worksheet, 1); { Loop through each row in column A of the worksheet } FOR row := 1 TO num_rows DO BEGIN { Get the data in the current row of column A } cell_data := GetWSCellFormulaN(worksheet, 1, row); { Find text objects that match the data in the current row of column A } text_objects := FindText(cell_data); { Select the text objects that match the data in the current row of column A } FOR i := 1 TO Count(text_objects) DO BEGIN SetSelect(text_objects[i], TRUE); END; END; END; Run(SelectTextObjects); Quote Link to comment
Pat Stanford Posted February 1 Share Posted February 1 It is a mess. 😞 Most of the functions/procedures don't actually exist (GetWSByName, GetWSCellNumRows, FindText) and the ones that do exist are being used incorrectly. Why don't you ask the OI (Online Intelligence: i.e. this forum) what you are trying to do and you will get much better results. 1 Quote Link to comment
Zsombor Posted February 1 Author Share Posted February 1 @Pat Stanford, thank you for your answer. I don't want ask anyone to write me a script. I thought it'll be just a small failure in an easy script like this. Quote Link to comment
Pat Stanford Posted February 1 Share Posted February 1 There are a number of us who think small scripts are a fun distraction. 😉 Quote Link to comment
Zsombor Posted February 2 Author Share Posted February 2 I see! In this case could you please help me with this? I have a list of codes (numbers and letters) in worksheet cells (only A column). I also have texts on a layer and I want to find the matching ones with my worksheet cells. (these are buliding site ID codes). Of course I could do that each by each with finding text command, but I gave it a try with AI. But really, only if it makes fun! Quote Link to comment
Pat Stanford Posted February 4 Share Posted February 4 Here is a script that should do what you want. Be careful as it will select text blocks that match the criteria but are not currently visible (hidden layers or classes). By commenting/uncommenting different lines, you can change the behavior of the script from an Exact Match to Begins With to Contains. Only one line can be uncommented at a time. As written below it does an exact match. Ask if you have more questions. Procedure SelectTextByWorksheetCell; {©2024 Pat Stanford - pat@coviana.com} {licensed under the Boost Software License 1.0} {https://github.com/boostorg/boost/blob/master/LICENSE_1_0.txt} {TL/DR Use as you want, attribution for source, No warranty} {This script takes the value of the selected cell in the top visible worksheet (open for editing)} {and then searches for text blocks in the drawing that have that value.} {In a file with many text block this could be a very slow operation.} {The script has three modes that can be set by changing which line is uncommented.} {Comment a line by placing braces (the characters at the beginning and end of this Line)} {at the beginning and end of the line. Uncomment a line by removing the braces.} {Only one of the three lines can be uncommmented at a time.} {If the first line is uncommented, the script will select items that are an EXACT MATCH} {for the value in the currently selected worksheet cell.} {If the secon line is uncommented, the script will select text items that BEGIN with} {the string in the currently selected worksheet cell.} {If the third line is uncommented, the script will select items that CONTAIN the string} {in the currenlty selected worksheet cell.} {This script can be slighty dangerous as it will select text items that match the Criteria} {but that are not currenlty visible, including text blocks on other layers or invisible} {classes. Be careful if you are using this to select items to modify or delete.} VAR WSHand, TextHand :Handle; Row1, Col1, N1 :Integer; WSString, TextString :DynArray of Char; Procedure Execute(Hd1:Handle); BEGIN If GetType(Hd1)=10 THEN BEGIN TextString:=GetText(Hd1); If TextString=WSString THEN (*Uncomment this line for exact match *) { If Pos(WSString, TextString)=1 THEN (*Uncomment this line for Begins With *) } { If POS(WSString, TextString)>0 THEN (*Uncomment this line for Contains *) } BEGIN SetSelect(Hd1); End; End; End; BEGIN DSelectAll; WSHand:=GetTopVisibleWS; GetWSSelection(WSHand, Row1, Col1, N1, N1, N1, N1, N1, N1); GetWSCellStringN(WSHand, Row1, Col1, WSString); ForEachObject(Execute, ((T=TEXT))); End; Run(SelectTextByWorksheetCell); Select Text By Worksheet Cell.vwx 1 Quote Link to comment
Zsombor Posted February 6 Author Share Posted February 6 Dear @Pat Stanford, I really apprepriate your kindness, and help! Awesome! It Works! Only one more question: If I undestood your instructions well, it finds always the matching text for the one selected cell. Would it be maybe possible to ask the script to run trough all the cells and give all the matches to the selection? (Just like I would use the shift button during selecting them manually). Or is this operation not possible? Thank you, Zsombor Quote Link to comment
Pat Stanford Posted February 6 Share Posted February 6 So you would like to select a range of cells in the worksheet and then select all the text items in the drawing that match ANY of those items? It is certainly possible to do this if that is what you want. In the meantime, if you comment out the DSelectAll; line, you could manually do the deselect and then the script would continue to add to the selection when you manually run it on different worksheet cells. Quote Link to comment
Pat Stanford Posted February 6 Share Posted February 6 I was going to wait for your response that this is what you want, but my brain insisted on doing this project before any of the other things I am supposed to be doing. So here is the version that checks and selects text in the drawing that matches any cell in the selected range of the worksheet. It seems to work fine with a single selected cell or selected cells in a column. I have not tested (though I wrote it to handle) a range of multiple columns. Procedure SelectTextByWorksheetCell; {©2024 Pat Stanford - pat@coviana.com} {licensed under the Boost Software License 1.0} {https://github.com/boostorg/boost/blob/master/LICENSE_1_0.txt} {TL/DR Use as you want, attribution for source, No warranty} {This script takes the values in the range of selected cells in the top visible worksheet (open for editing)} {and then searches for text blocks in the drawing that have those values.} {In a file with many text block this could be a very slow operation.} {The script has three modes that can be set by changing which line is uncommented.} {Comment a line by placing braces (the characters at the beginning and end of this Line)} {at the beginning and end of the line. Uncomment a line by removing the braces.} {Only one of the three lines can be uncommmented at a time.} {If the first line is uncommented, the script will select items that are an EXACT MATCH} {for the value in the currently selected worksheet cell.} {If the secon line is uncommented, the script will select text items that BEGIN with} {the string in the currently selected worksheet cell.} {If the third line is uncommented, the script will select items that CONTAIN the string} {in the currenlty selected worksheet cell.} {This script can be slighty dangerous as it will select text items that match the Criteria} {but that are not currenlty visible, including text blocks on other layers or invisible} {classes. Be careful if you are using this to select items to modify or delete.} VAR WSHand, TextHand :Handle; Row1, Col1, N1 :Integer; TopRow, BotRow, LeftCol,RightCol, TopSubRow, BotSubRow :Integer; RowCnt, ColCnt :Integer; WSString, TextString :DynArray of Char; Procedure Execute(Hd1:Handle); BEGIN If GetType(Hd1)=10 THEN BEGIN TextString:=GetText(Hd1); If TextString=WSString THEN (*Uncomment this line for exact match *) { If Pos(WSString, TextString)=1 THEN (*Uncomment this line for Begins With *) } { If POS(WSString, TextString)>0 THEN (*Uncomment this line for Contains *) } BEGIN SetSelect(Hd1); End; End; End; BEGIN DSelectAll; WSHand:=GetTopVisibleWS; GetWSSelection(WSHand, Row1, Col1, TopRow, LeftCol, TopSubRow, BotRow,RightCol, BotSubRow); For RowCnt := TopRow To BotRow DO BEGIN For ColCnt := LeftCol to RightCol DO BEGIN GetWSCellStringN(WSHand, RowCnt, ColCnt, WSString); ForEachObject(Execute, ((T=TEXT))); End; End; End; Run(SelectTextByWorksheetCell); Quote Link to comment
Zsombor Posted February 7 Author Share Posted February 7 It works like a charm! Really, really thank you for you kind help! Maybe I should give some time for learning scripting... Have a nice day, Zsombor Quote Link to comment
Pat Stanford Posted February 7 Share Posted February 7 If you decide to learn, just pick a relatively simple project (like this one) and ask questions. There are a bunch of us who like scripting and like to help people learn to script. Glad it works for you. 1 Quote Link to comment
