LeeElston Posted January 30, 2024 Share Posted January 30, 2024 Is there a way of setting the scale in the Title block sheet data to update automatically, rather than having to do it manually... Not a massive issue but one thing less to think about...TIA Quote Link to comment
Tom W. Posted January 30, 2024 Share Posted January 30, 2024 I don't use a scale in the TBB but I believe the Scale field should automatically be the same as the DL scale or the scale of the first VP on the sheet. How does it work for you? I have the scale in the VPs as I generally have multiple VPs per A1 sheet + often at different scales... 1 Quote Link to comment
Vectorworks, Inc Employee Domas Posted January 30, 2024 Vectorworks, Inc Employee Share Posted January 30, 2024 Hello @LeeElston, I don't think that is possible at the moment. As far as I know, the scale button is taking the scale from the first created viewport on the sheet and that needs to be updated manually. I think the best way to proceed here would be to use the Title Block Manager tool. That is under File - Title Block Manager. With this tool you can select all Title Blocks and amend them through there. Open the Title Block Manager tool. A message will ask if you would like to use multiple files to amend or the active file only. Please choose Load Active File Only and another window will open. There you can select Sheets To Use and apply sheet data updates to all of them with a single click. 2 Quote Link to comment
Ross Harris Posted January 31, 2024 Share Posted January 31, 2024 (edited) This is something that should be updated when the drawing set is published. Other softwares manage this - at the moment it's just another thing to forget when under pressure. At the very least it should be significantly easier than the process to update them all as noted above. Edited January 31, 2024 by Ross Harris Quote Link to comment
