Harpahei Posted January 25, 2024 Share Posted January 25, 2024 I have these walls that are identical and can be seen in all views, but some of them disappear when I switch to top/plan view. Any idea why this could be and what I can do to fix it? Quote Link to comment
cberg Posted January 25, 2024 Share Posted January 25, 2024 (edited) Try switching the bottom bound to something like layer elevation.... See if that fixes the problem. Otherwise, maybe try deleting wall peaks under the AEC command menu. Otherwise try healing the wall and rejoining... Edited January 25, 2024 by cberg Quote Link to comment
cberg Posted January 25, 2024 Share Posted January 25, 2024 The only other thing that I see is that you are not in the same layer as the wall. Make sure to right click on the wall and activate the layer... 1 Quote Link to comment
Tom W. Posted January 25, 2024 Share Posted January 25, 2024 Also try sending the Slab to back in Top/Plan if they're on the same layer. The walls could be hidden behind the Slab in the 2D stacking order. 3 Quote Link to comment
Harpahei Posted January 26, 2024 Author Share Posted January 26, 2024 23 hours ago, Tom W. said: Also try sending the Slab to back in Top/Plan if they're on the same layer. The walls could be hidden behind the Slab in the 2D stacking order. I think that may have been the issue. I started cleaning up the whole file, it's my first model in VW and I've probably made a ton of mistakes along the way, so I made a new file and deleted all the layers I'm not using anymore and organised them better. That seems to have solved the issue, whether it was putting the slab on the correct layer or just generally cleaning things up 🙂 Quote Link to comment
